03-10-2021 08:24 PM
Greetings!
I've been using my m50 for a little over a year now in manual video mode teathered to a PC via an Elgato CamLink and EOS Utility 3 (v3.13).
For several months the usb connection has been a bit finicky and prone to disconnecting from the EOS Utility. Lately I barely touch the connection and it'll drop/reconnect, and often will just randomly decide to drop connection a couple times an hour.
Starting today the HDMI is showing similar symptoms. It'll randomly drop connection or momentarily display a blue cast to the output.
Any ideas as to what's going wrong?
03-11-2021 01:02 AM
Both the USB output and HDMI port are part of the same circuit board, its possible an issue in one may predict the next. I would definitely try a new USB or HDMI cable but since you are experiencing the same issue with both cables already I suspect the camera is the cause and repair would be the best solution.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
