M200 - wont turn on but flashes green light
Cball615
  1. I have an M200 that I purchased at Christmas.   The LCD wont turn on and nothing seems to work but the green light at the top flashes.   Any ideas on what could be wrong ?
11 REPLIES 11
deebatman316
Have you tried to power up the camera with the lens, SD Card and other accessories removed. From the camera to see if the camera will power up at all.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Cball615
When I take off lens and remove sd card…I dont even get the flashing green light.
Will the camera power up with those items removed.
-Demetrius
Cball615
No…unfortunately it doesn’t…..when I take off the lens….I still get the flashing green light without powering up but when I remove the SD card…..I get no green blinking light along with it not powering up.  Wondering if it’s a battery problem or a camera problem or something else.
If you have a spare battery test the camera with it. If it still behaves the same after using the spare battery you'll need to contact Canon.
-Demetrius
mahapjyo
I have the exact same problem ! Did you find a solution for this ? I still haven't found anything.
Did you test with a second battery? Also with a second memory card?  As a last suggestion, you should also try removing and remounting the lens to the body.
I did, try a new battery and memory card.  But the screen just wont show up.
If a new battery and card don't resolve with the lens detached, you will need to contact support.
MyCanon
