05-01-2021 11:13 AM
I'm looking for an L-Bracket that will work with my 90D when the battery grip is mounted.
By work I mean that the battery sleeve can be removed from the camera without having to remove the bracket. I have a generic long bracket but there is no opening for the battery sleeve and removing it is a pain in the ass.
Wondering (1) if there is such a beast or (2) if a bracket made for a 5D/6D/R might work? Does anyone have any suggestions?
Thanks in advance.
05-01-2021 12:49 PM
ProMedia Gear has one.
05-01-2021 12:10 PM - edited 05-01-2021 12:16 PM
Edit: Oops, I completely missed the part of the battery grip (assuming you have the BG-E14 part?).
Really Right Stuff makes a modular L-bracket specific for the EOS 90D. Modular in that you can choose to only mount the bottom plate, or to also include the side (L-part). However, I cannot seem to find if they have any brackets for the BG-E14.
If you find something from them, I can attest that they are extremely well-made. I use their modular L-bracket specific to my EOS 5D IV (no battery grip). It allows for unblocked access to the battery compartment as well as to the ports on the side (USB, remote, etc.).
I don't think you can mix-and-match their products on other camera bodies/grips as each bracket they make is specific to a particular body.
Though maybe they carry a "universal" version? not sure.
05-01-2021 12:49 PM
05-01-2021 02:35 PM
@Carbon14 wrote:I'm looking for an L-Bracket that will work with my 90D when the battery grip is mounted.
Thanks in advance.
The different series of cameras all use a different L Bracket because of the slight differences in physical size dimenasions, and location of access ports and panels on the side of the camera. These are also the exact reasons why using a "universal", one bracket fits all cameras, is highly inadvisable. It is quite likely that once you install it on the camera, then you may not be able to access any of the ports because the bracket is in the way.
05-01-2021 07:48 PM
Thanks I'll take a look over there.
Where I have netted out: It does not appear ANYONE has made an L-Bracket for the 90D and battery grip. I suspect other brackets that fit other models might work but there is no retailer I can visit to test that theory.
SO -- I bought an L-Bracket from <Unknown Amazon Retailer> for $15. Apart from lacking neoprene padding, it seems more than adequate. Aluminum frame, steel 1/4 screws. I don't use the camera in that mode often so this might be just fine.
We'll see. 😉
Thanks for your help.
05-01-2021 07:51 PM - edited 05-01-2021 07:58 PM
Yes, saw that.
While I prescribe to the mantra "beggars can't be choosers" I found this one looked like it was created to avoid dealing with the ports AND the swing display -- so it's snaking upper frame really draws attention to itself 😉
If all else fails, I may consider it but thank you for looking that up and for sharing.
