09-05-2017 11:42 PM
I've been having issues with my Canon Rebel T5 the past couple days. Whenever I try to take more than a couple pictures at a time, the screen goes black, I can't review the photos I've taken, and the pictures don't save. When I take out the battery and put it back in, I can take photos again but only a few before it does the same thing.
I should note that I had to adjust my settings in Manual mode to take photos of a soccer game the other night, so that might have something to do with it.
09-06-2017 06:22 AM
Make sure your battery is fully charged. Use only genuine Canon batteries and chargers.
Make sure you use a name brand, full size SD memory card. Also, avoid micro-SD cards, and a card capacity of over 32 GB. Be sure to do a low level format of the memory card in the camera, too.
Make sure the battery door and the memory card door are securely closed. If you are still having problems, contact Canon Support.
09-06-2017 12:07 PM
" If you are still having problems, contact Canon Support."
"I should note that I had to adjust my settings in Manual mode..." ![]()
Hold on the reins there cowboy! Try clearing all settings first. Under the Tools menu. That doesn't fix it than contact Canon.
