07-14-2023 11:54 AM
I went to update my firmware of 70D suddenly it stuck then i tried to reinstall the battery it didnt helped. Now i m stuck the firmware update menu what should i do now
07-14-2023 12:16 PM
Disconnecting power is the LAST thing you should have done. Interrupting a firmware update likely has crippled your camera. This is something requiring Canon's service assistance, if even they can salvage it.
07-14-2023 12:18 PM
Can u tell me how can i talk with them at online
07-14-2023 12:22 PM - edited 07-14-2023 12:24 PM
If you're in the United States, we encourage you to call our support team at 1-800-OK-CANON (1-800-652-2666). They're available weekdays and Saturdays. You can also find additional support options when you register your camera as part of your MyCanon account.
If you live elsewhere, you'll need to contact the Canon company that serves your part of the world. You can find them by clicking here and then clicking on the map to select your region or country.
Hope this helps!
07-14-2023 03:31 PM - edited 07-14-2023 03:44 PM
Assuming a Windows computer was used to download the file, open the .zip file and extract the .fir file to the root of the SD card. Put it in the camera and start the firmware update process again. Are you positive that you downloaded the correct firmware file for the EOS 70D camera?
07-14-2023 05:31 PM
You're assuming the camera is not bricked because of the interruption of the first update, either by a glitch or by battery dying/removal.
07-14-2023 09:38 PM
if i remove the memory card it says update file cannot be found . if insert the memory file it stucked at the 36% then it says check the memory card then reload the battery . i bring another memory card and tried the process it didnt helped
07-14-2023 10:29 PM
Diagnosis is straight forward. If you don't have a memory card installed, does the camera start normally, or does it display the firmware update menu only? You indicated you have tried 2 different cards with the same result and the camera will not proceed past 36%.
If the firmware update menu is all that displays, the camera is bricked and it's existing FW is corrupt. The device will need to be sent to canon for service. I'm sorry, but this is not something that can be resolved via chat, with the EOS Utility or remotely. Please open a support case and prepare to send your camera in for repair.
