10-29-2014 11:16 AM
11-26-2014 11:23 AM
You can also buy an external card reader for your computer and put the camera's memory card in the reader to copy the images.
I do this with my cameras mostly because the locally attached card reader can transfer images faster than the USB connection.
11-23-2014 10:24 AM
There are no drivers availible and none are needed for Windoze to see the camera. You do, indeed, need to set the camera to the correct setting which is PTP, Picture Transfer Protocol.
11-23-2014 04:48 PM
Thank you ebiggs1. I will try it.
tklein559
11-26-2014 11:23 AM
11-26-2014 12:16 PM
Tim,
I do have a card reader and found that solution before learning that there is a setting on the camer(PTP) which I have yet to try. Thank you. TKlein559
