04-14-2014 09:15 PM
I use the yongnuo wireless triggers and receivers for my studio strobe monolights. My 5diii works fine, however, my wife's Rebel SL1 wiill not trigger them.
What do I have to do to make them work?
Jim
04-14-2014 09:35 PM
Which triggers are you using?
I have Yongnuo YN-622C's and use them on both my SL1 and 5D Mk III with no problems at all. The Flash Menu looks almost identical on both cameras so I would take a look at the flash menu items to see if they are set up the same.
The only thing I can think of off-hand is that you might have "Flash Firing" set to "Disable".
04-14-2014 09:42 PM
Hi Mike, thanks for the reply...they are the Yongnuo 602 series. I checked to "Flash firing" and it is enabled. The mystery continues.
04-16-2014 12:18 PM
Put a flash on the SL1 and verify the hotshoe works.
There's no reason why the 602s wouldn't work on it. They're a fully manual trigger, in other words, very simple. So long as it makes contact with the center lead it should work fine.
