How to get pictures off of an EOS Digital Rebel XT
har-leigh
I need help with figuring out how to get my pictures from the Canon Rebel XT onto my laptop. Ive tried almost everything and i downloaded the canon app and my camera is so old that it doesnt pop up. Please help...Thanks!
2 REPLIES 2
kvbarkley
VIP
VIP
Just get a CF card reader.
Otherwise, jut plug it into the computer and select "PTP Communications"* from the menu.
Mac or PC?
*Which is contrary to what the manual says.
Tronhard
Absolutely agree with my colleague @KVBarkley.   The simplest, fastest and most reliable method to get files off your camera is to use an appropriate internal or USB-connected card reader.  Please note that you need a CF card reader, not a CF Express one - they sound similar but are totally different units.
The procedure, once you have said card reader is:
Connect the card reader to your computer
Shut down the camera
Remove the card and carefully insert it into the reader - these cards have to connect with pins in the reader, so be careful lining them up as forcing it in can bend or break the pins, disabling the reader.
Once attached, your computer file manager should see the card as a removable drive.
You can then open the folder DCIM and copy the contents to wherever you want on your own hard drive system
Once completed, check the files are there
Eject (Windows command) the card from the computer
Reinstall it into the camera
Turn the camera on
Format the card clean, using the camera's format command.
cheers, TREVOR
The mark of good photographer is not what they hold in their hand, it's what they hold in their head;
Avatar
