How to add mic input on Canon EOS 1200D?
Anonymous12
Hello,
I am one of the consumer of Canon EOS 1200D with EF 18-55 MM Kit. I noticed that it doesn't have an audio input. However, I like to record audio from my mixer and video from my DSLR simultaneeously without video editing. Is there a way to add an audio input to the camera?
Thanks
Waddizzle
Negative.  You must record your audio separately, and then use video editing.  Use a digital slate to sync audio and video.
9 REPLIES 9
Waddizzle
Thank you for replying.
Is connecting a 2.5 mm jack to the remote connector allows me to record audio and video simultaneously? Thanks
Negative.  There are no audio inputs associated with that connector on a T5.  None.
Ok, Thanks for the helpful response.Smiley Happy
Actually, come to think of it, you will record audio and video simultaneously.  Audio will be recorded by the built-in microphone.
This is the second time recently that this bit of misunderstanding has popped up. Where do people get this idea?
The plug connector is identical to that typically used for a microphone input, stereo or mono.
I know, but even if I thought you could randomly stick 2.5mm plugs into any 2.5 mm jack and have it work, I would think "headphone", not "microphone"
Avatar
