10-25-2020 10:38 PM
Is there any way on the R5 to determine how many exposures were taken when using focus bracketing other than looking at the battery info. screen before and after the focus bracketing series? Thanks.
10-28-2020 01:23 AM
Hi there,
Other than the method you mentioned, the display on the back of your camera will show a frame number of the total pictures taken, so either seeing the total before shooting and comparing after, or looking at the first frame's number and then the number from the last frame would be the way to do it. I don't see anything in the manual which would indicate it will tell you how many shots in the stack necessarily.
10-28-2020 01:23 AM
Hi there,
10-28-2020 02:32 PM
Good suggestion. Thanks.
