04-19-2021 08:17 AM
I was taking some photos with my T7 a while back. The histogram was on the screen and bfrought a questionto mind. I have played with the histogram on DPP4. Could one use the "graph" on the histogram to adjust settings for f-stop, ISO, shutter speed, etc.? Thanks.
04-19-2021 08:40 AM
I'm not sure what you're asking. I haven't used DPP, but are you speaking to the ability to drag on various zones in the Histogram (what you can do in Lightroom) to adjust exposure, shadows, whites, etc.?
If so, the histogram is just a visual representation of the quantity of pixels at each level. Camera histograms are non-adjustable in the sense they just show a read-only view of the photo's data.
Also, while dragging zones in a photo editor's histogram would change exposure, shadows, etc, it would not in any way affect the f-stop or shutter speed.
04-19-2021 09:26 AM
@Tintype_18 wrote:I was taking some photos with my T7 a while back. The histogram was on the screen and bfrought a questionto mind. I have played with the histogram on DPP4. Could one use the "graph" on the histogram to adjust settings for f-stop, ISO, shutter speed, etc.? Thanks.
Expanding on Ricky's response:
1. if you are looking at the histogram when you are playing back an image already taken the histogram is history - it shows the image as you captured it.\
2. if you are using LiveView you can't adjust anything by using the histogram, but you can adjust camera settings and see how the histogram changes.
04-19-2021 11:18 AM - edited 04-19-2021 11:18 AM
Need to be a bit more precise here. The camera shows the histogram on the LCD screen. I'm thinking I can take additional photos to "shift" the peaks and alleys of the histogram to affect the photo. Sort of "editing" with the settings.
John Hoffman's item #2 is what I'm looking at.
Thanks to all.
04-21-2021 10:31 AM
"... I can take additional photos to "shift" the peaks and alleys of the histogram to affect the photo."
The best place to use the histogram is in post editing. However, the most important parts are not the peaks and valleys but either end. The histogram should go completely to each end. If you take a shot and notice that is doesn't you can try a different exposure setting to make sure that is does extend to both ends. The bottom line of the histogram that goes from left to right shows 0% brightness, or black, to 100% brightness, or white. Oh, BTW, your histogram should not spill over the ends either.
Always shoot Raw so you get the very most editing ability.
04-21-2021 05:43 PM
You can only move the whole histogram to the left or the right. You cannot change the dynamic range (except with digital lighting optimiser). Besides, how will you tell the camera which to adjust: aperture, shutter or ISO?
04-21-2021 06:02 PM
04-21-2021 07:33 PM
@kvbarkley wrote:You can only move the whole histogram to the left or the right. You cannot change the dynamic range (except with digital lighting optimiser). Besides, how will you tell the camera which to adjust: aperture, shutter or ISO?
Actually, you can "stretch" the dynamic range to a fairly significant degree. I have watched a couple of astrophotography videos on YouTube that show you how to do it. You will never go completely side to side. But, you can take an image that is butting up against one side and stretch it out towards the center quite a bit.
04-21-2021 07:57 PM
Please post a link to this. And remeber, we are talking in-camera, not in post.
04-21-2021 08:17 PM
Ah, no. My mistake. I was speaking about post processing. No in the camera.
