‎02-21-2025 02:00 PM
Hello there, I've recently started taking more pictures with my new R6mk2, I did alter some settings when I first got the camera and then ended up wiping everything and started again. I've used the camera today and when I change the dial from M mode to Av mode, a cartoon graphic appears on the screen and/or viewfinder. I could have sworn I found a way of switching this off before I wiped all the settings but I can't seem to find how I did it, or even if it's possible, maybe you can't switch it off. Does anyone know if it's possible and if so, how? TIA.
‎02-21-2025 02:32 PM
In the Wrench (yellow) menu, Item 2, disable "Mode guide". That should do it 🙂
Newton
Newton
‎02-21-2025 02:40 PM
Thank you Sir! That's it, I can't believe I didn't spot it before. Have a great day and let me leave you with a joke...A man went to the Doctors and complained he was feeling like a bell. The Doctor told him to go home, lie down in bed for a couple of days and if he wasn't feeling any better, to give him a ring.
