11-24-2020 03:24 PM
I apologize for posting another subject so quickly, but I want to make sure I do the right thing here.
Today I was at a used Camera store and I was trying out a lens on my camera (Maybe 5 minutes most). After looking at the lens, I noticed there was some fungus on the very middle element. Of course I didn't put the lens back on the camera after that. I should of checked before.
However, I'm hoping it didn't contaminate my camera body. Should I get the sensor cleaned? or is there something else I should do?
Sorry never delt with fungus before.
The camera sensor looks new still, but I've heard fungus can spread easily.
11-25-2020 01:49 PM
Ernie,
I suspect those lingering darkroom chemicals won't allow anything to grow 🙂
I shoot a lot of sports stuff in bad weather so the gear often gets wet and I am not giving fungus a chance.
Rodger
11-25-2020 02:30 PM
"...I am not giving fungus a chance."
I should say!
You have to keep on top of because the silica only last for six to 12 months if it is in a sealed container. Opening it let's new humidity in the case which alters its shelf life. It can be dried, though. So, you see I did think about it along time ago. I just felt it was too much trouble for too little reward.
I have often wondered and now it comes to mind once more, how many lenses I have owned? Not to mention how many I had access to from work. ![]()
11-25-2020 05:29 PM
Ernie,
I think having a fungus issue is pretty rare for most users unless they live in the tropics. Until I started shooting a lot of sports in bad weather I never bothered with any special precautions for the camera gear. But it seemed like a good idea after the cameras and I sometimes spend hours outside in horrible weather. I have shot a few swim meets and those are probably even worse but it was in the depths of winter so they dehumidified quickly once I left the event.
I have a bunch of silica very large silica packs from the electronics work that I do along with a small environmental chamber I used for some electronics projects years ago so it is easy to dry out the silica packs and keep them functional.
I would expect that only a tiny percentage of camera owners will ever have an issue with stuff growing in the lens but once it starts it would be a problem. Some of the early plastic materials in some of the vintage radio gear I have restored are like Petri dishes for fungus and many of these early formulations have a similar weakness to Bakelite; stuff sufficient to clean and disinfect often takes off the thin outer layer that formed when it cured and nothing will ever make them look exactly the same again once that layer is damaged or removed.
Rodger
11-26-2020 11:44 AM
It is really curious to see the extreme ends people go. I have seen full timers abuse gear to level I think unimaginable. And, then on the other hand there are folks that treat their gear fastidiously. I guess I fall somewhere in between?
On one occasion at a pro football game I saw a guy sit on his camera and 600mm telephoto while eating a snack! Yup, using it for a stool. And lens caps, who needs lens caps? Me, I do reasonable care but not extensive. Nothing gets really abused but it does what I want or it's gone. I feel if I can take it, my gear can take it. Then, I have a friend that is **bleep** about his gear. He doesn't have a lot but it all looks brand new. He even has and uses a changing bag to switch lenses when we are on an outing. There is all levels for sure.
11-27-2020 03:43 PM
@wq9nsc wrote:Use a "pocket rocket" or similar to blow out the camera. Keep it pointed downward. Wipe the external surfaces of the camera with an alcohol wipe.
Rodger
. . . And I'm sure you meant to keep the camera body pointed downward when the lens is removed, in which case you'll have to point your Rocket blower upward to blow out the inside of the camera body. ![]()
