02-12-2014 02:39 PM
Please help, I changed my iphone 5s and forgot the password connected to my Cannon 6D, possible to reset, I can't find any instruction from Manual. Thanks.
09-14-2021 10:19 AM
Thank you! It ended up being the encryption number. Also, I realized I was not giving it enough time to connect. I immediately got the message "connected, no internet" every time I tried. I finally gave it about 30-60 seconds and it connected.
Thank you!!
05-08-2022 11:38 AM - edited 05-08-2022 11:39 AM
I have a canon eos 2000d and I have figured this out. We didn’t actually set a password for our cameras. Canon give you a one-time 8 digit number to put into the ‘password’ location on wifi.
You can find this number if you go to wifi function > connect to smartphone > review/change settings > change set > now make sure it is ‘easy connection’ you have selected, then select ‘OK’ and it will give you the SSID (the name of your camera) and the encryption key (the one time password). Keep this screen open on your camera while you type it into your phone and it should connect.
I hope this helps!
05-08-2022 10:09 PM
This should help. No connection to a computer is required.
Support | DSLR | EOS 6D | Canon USA
05-09-2022 08:56 AM
Re: passwords; I have a notebook with about eight pages of passwords for various stores, auctions and websites, both past and present. They are written in a code that only I can read. I don't trust my memory, especially at my age.
