Focusing Issues
bertotr
Hi everyone,
I had the unfortunate event of a circuit board failure on my 60D while on vacation. Luckily it happened towards the end of the trip. It was repaired by a third party as it was no longer supported by Canon. I have a Sigma 18-35mm attached to the lens. Prior to issue, my photos were sharp and no need for lens adjustment. Since I received the camera I have been having blurry images. I have reset the camera to factory settings, formated the SD card with the latest firmware and tried another Canon lens. When I view the image via the optical viewfinder it looks in focus but when uploaded they look blurry. I used the auto live view screen and the same picure looked great. I don't know what to do next.
Thank you for your help.
RobertTaken with Live ViewTaken with Optical View Finder
6 REPLIES 6
Waddizzle
Sounds like the third party repairs may not have been done properly.  Perhaps a calibration needed to be performed that was not.  Send the camera back.  If they “correct” it, then sell it and upgrade.  That camera may never “right” again, if Canon do the repairs.
ebiggs1
At this point I think you need to cut your loses.  It is only going to cost you more and you are still going to end up with 8 years old camera.  Not the best idea, do you think?
Perhaps you can try to get the shop to redo it but if they screwed it up the first time how well do you think they will do the second time?
EOS 1DX and many lenses.
ebiggs1
"I have reset the camera to factory settings, formated the SD card with the latest firmware and tried another Canon lens."
None of that is the problem or will help. Sorry.  Smiley Sad
Ray-uk
Whiz
Most modern cameras will need recalibrating using the special manufacturers software when a main board is replaced. I would guess the repairer you chose didn't realise this or didn't have the necessary software.
bertotr
Thank you all for your help. Will upgrade to the 90D.
Waddizzle
“Thank you all for your help. Will upgrade to the 90D.”
You are going to need some new socks with the 90D! Enjoy it.
