06-20-2026 06:42 AM
just bought the eso r100, the flash on camera is not work has a flashing orange light but no flash coming on
06-20-2026 07:56 AM
Do you mean a built in flash?
Is the battery fully charged?
When do you see a flashing orange light? Where is it located?
06-20-2026 10:21 AM
Yes built in flash,near the name eso
06-20-2026 11:57 AM
I assumed that you meant to say EOS, not ESO. That orange light is not the flash. It’s the focus assist beam. It activates when you are trying to take photos in dark places.
the onboard flash is on top of the camera . It automatically activates only in certain shooting modes. It can also be manually raised
Press the lightning bolt button to manually raise the flash.
06-20-2026 10:13 PM
Flash still does not appear to fire on camera even in dark places, just the orange light flashes
06-20-2026 10:15 PM
I already have the flash raise and some how it doesn’t fire the flash
06-20-2026 11:51 PM - edited 06-20-2026 11:51 PM
Samtovar302001,
Are you sure that your flash is on or has been enabled in your settings?
Are you in one of the Creative Modes: M?, Av?, Tv?, P?
Here is a troubleshooting guide you can check if your flash is not working:
https://illustratedphotography.net/canon-eos-r100-flash-not-working-po1670/
Steve Thomas
06-21-2026 12:01 AM - edited 06-21-2026 12:24 AM
It’s on manual Ive reset the camera flash and I have raised flash up and I’ve also checked the flash to be enabled and fire settings as well but when I take the picture it’s just a black screen camera battery is full I’ve already look up it on YouTube to see if that I can get help on there and I’ve tried everything
06-21-2026 07:55 AM - edited 06-21-2026 08:04 AM
“!It’s on manual Ive reset the camera flash and I have raised flash up and I’ve also checked the flash to be enabled and fire settings as well but when I take the picture it’s just a black screen camera battery is full I’ve already look up it on YouTube to see if that I can get help on there and I’ve tried everything ”
what shooting mode are you using? It doesn’t flash in all shooting modes. Try using Intelligent Auto, as shown in the image below. Use the viewfinder,
If it still doesn’t work, then you should try to reset the camera. You may need to change the top shooting mode dial to P to make reset option appear in the menus.
Retest using Intelligent Auto Mode. If it’s still not working, then your camera may need service.
06-21-2026 08:18 AM
Put the camera in A+ mode. Make sure your lens is on it, and it's in Auto Focus mode. Go into a dimly lit area (not pitch dark), point the camera at a subject that you would normally want to take a photo of (a person or object - not the wall, the floor, lines on a piece of paper or a completely black room). In A+ mode, the camera is going to do all of the work. In MANUAL mode, YOU must do all of the work.
If you do this, and the flash doesn't work, call support so they can help determine if it's a misunderstanding of operation or a malfunction. Our team is available weekdays from 9am to 6pm (ET) at 800-OK-CANON (800-652-2666).
