03-05-2022 02:44 PM
So i just bought the camera off marketplace a few months ago and everything was working fine.
Just a few days ago i went to take some pictures so i popped the flash up and went to shoot but the flash wasn't firing.
It sounds like it tries to fire but the light doesn't actually turn on.
Occasionally when trying to focus the flash will turn on for a split second just once and then it will continue not working.
I tried recharging the battery and doing a factory reset but still nothing
It doesn't matter what mode im on the flash won't fire. I checked to see if dirt or anything got into the small button but there is none and the button is up fine.
I have no idea what to do... Any suggestions??
03-05-2022 05:13 PM
Switch the camera to the Green [A+] shooting mode and test the flash indoors with normal lighting. In most circumstances, average room lighting should cause the camera to enable the onboard flash and use it.
However, be aware that the onboard flash is not very powerful. Strobes can draw a lot of current and quickly run down a fully charged battery. If the flash were working properly, then you will notice that it projects a pretty harsh light and is not very effective beyond 2-3 meters, or 7-10 feet.
03-06-2022 10:19 AM - edited 03-06-2022 10:20 AM
"I tried ... doing a factory reset but still nothing"
Are you sure? There are two controls you need to reset. Menus, Tools, Clear all settings and Clear all Custom settings. If the flash is popping up then the camera thinks it needs it. Flash tubes do burn out.
"Switch the camera to the Green [A+] shooting mode and test the flash indoors with ... ."
I would try that but I would add do it in a darkened room. Make sure the camera thinks it needs the flash. But first make sure you do the complete reset. Other than that there isn't much you can do.
