External Mic not working
ItNeverWorks
I have a Eos Rebel T3i 80D, I got an external powered mic (comica V30) and when I plug it in the audio dies. The mic is definitely plugged in all the way, it has external power, I can't figure out the problem. This is the second mic I have tried both had this same issue.
10 REPLIES 10
MikeSowsun
What do mean by “ it has external power”. Isn’t there a internal battery inside the microphone?
Mike Sowsun
Yes the mic has its own battery power, it's not drawing power from the camera.
Do  you have both a T3i and 80D and they both don’t work? Check each camera sound recording menu. There is an option to disable audio input.
Mike Sowsun
When I plug the mic in the dB meter goes to zero and it stays there. Same with it set to automatic as well as manual. No sound registers. Microphone works instantly on my smart phone, can't get it to work on the Canon. There really aren't any options on the menu so it doesnt seem there is anything else I can do?
There May be some kind of compatibility issue with that brand of microphone. I would try another brand to see if the camera actually works.
Other than that, a call or trip to the Canon Service department may be in order.
Mike Sowsun
ramogr
Hi. Did you find a solution? I have the same problem. Acutally, i filmed before with an external mic and it worked, now i tried and is just merely not working 🤷‍♀️
Any solution yet?
I have the exact same issue with a mic that i bought today.
One solution: Adapter (three to two connectors).
New microphone might have a plug with three connectors. And your Canon camera might have a jack for two connectors.
In this case, the solution is to buy an adapter.
mrmillmill
Hello I had the same issue with my canon t3i and I am using the PowerDeWise lapel mic. I was fortunate since the lapel mic comes with an adapter which is a 4 to 3 pin adapter. This adapter is needed for plugging in an external mic to the canon t3i.
Friends and Family
