07-15-2020 03:38 PM
Not sure this would be a problem with the shutter or mirror... or mirror bracket. Not sure on the terminology for all these parts so you'll have to bear with me. I can hear the shutter or mirror lagging when taking a shot then it gives me either the Err 20 or Err 30 message on the viewscreen. Attached are some pictures showing what they look like when this happened. It has the same dark area when taking video too although its always in the same area whereas the still shots it seems to show up in different areas of the frame.
Thanks for any help you can give me,
Steve
This was a shot of a hummingbird... The second shot was taken out the window in the house.
07-15-2020 07:11 PM
I'm guessing shutter failure.
You can take lens off, switch to LiveView and see what is against the sensor.
07-15-2020 07:20 PM
Thanks, I'll give that a try and see what I get. Appreciate it
07-15-2020 08:17 PM
I'm guessing this is the shutter partially blocking the image sensor then John? Never would have thought about trying Live View to diagnose this issue though.
07-15-2020 10:32 PM
07-16-2020 12:54 PM
Thanks for the tip, found a shutter blade repair assembly for $50 but still not sure I want to attempt this myself or not. appreciate the help for sure man.
07-17-2020 10:47 AM
"...not sure I want to attempt this myself or not."
You don't. Call Canon 1 (800) 652-2666
