07-28-2016 12:25 AM
I do eBay listings for someone. When I am out of town, someone else needs to take pictures. So, we purchased a Rebel T4i at a pawn shop (barely had 1,000 shutter activations on it). It needed a flash, as the conditions in the warehouse are not always optimal for taking pictures.
So, we acquired a 430EX flash. The problem is that no matter what position the flash is in, the pictures are always washed out. We have a cheap Bower SFD35C flash that we were using with it (cost about $30). It does an okay job, but doesn't light up the items enough (they are kind of dark, but never washed out like with the 430EX).
The camera that I personally use for taking the pictures is a Sony Alpha A65 with an HVL-F58AM flash. I keep the flash angled one click backwards and the pictures always turn out fine. Since I do not have experience with the Canon cameras, can anyone guide me as to setting up the camera and the flash to work together?? I am actually beginning to wonder if the flash is defective (it was purchased used), since once I take a picture, I can no longer adjust any settings on the flash until I turn it off and on again.
If anyone has any ideas or pointers, your input will be greatly appreciated. Thanks in advance.
07-28-2016 06:31 AM
Are you shooting in ETTL flash mode or manual flash mode?
07-28-2016 11:01 AM
I am shooting in ETTL mode.
07-28-2016 11:05 AM
Is your shooting distance within the range shown on the flash LCD?
07-29-2016 06:29 PM
None of those things show up on the flash ever. I am beginning to think the flash is not working properly or it is not syncing with the camera.
07-28-2016 07:20 AM
Does the on-camera flash work properly?
That flash behavior doesn't sound right. That doesn't happen with mine.
07-28-2016 08:47 AM
Don't forget to check the usual suspects like flash and exposure compensation.
07-28-2016 09:19 AM
Also, this sounds like you are shooting small things, are you using a soft box or anything? You might be too close.
07-28-2016 11:06 AM
The items are too big for a soft box. I shoot from the same distances with my Alpha A65 and the pictures are never washed out. I suspect that some settings in the camera are wrong or the flash is defective.
07-28-2016 11:07 AM
Use P mode and turn down the flash exposure compensation.
