06-17-2021 03:07 PM
I was just in checking something and looked to see if Canon had snuck a firmware update in for the R, when I noticed that the latest version says 1.8.0 which is what I have, BUT the date is listed as 6-9-21. I have that update but from 12-2020. I did not dload the "newer" version as the number has not changed. Any ideas?
06-17-2021 05:29 PM
06-17-2021 05:45 PM
I am aware of that, which is why I was wondering about the date on the website changing!
06-17-2021 07:33 PM
A new download server would be one explanation for it.
06-18-2021 03:03 PM
Opening the respective FIR files in a FireOne editor shows a definite difference.
The "older" version was compiled on Oct 21, 2020, while the currently available one was last compiled on Feb. 4, 2021
The newest version contains 2112 more bytes of code. There is no easy way to tell what the actual changes are, but they may be a fix for a minor, obscure bug or two, OR they just may be a few comments added by the author to allow for better documentation of the code.
Obviously, the diffence is not enough for Canon to justify a version numbering change and to trigger a firnmware update for all users.
06-18-2021 03:58 PM
Well, thanks for looking at it. I am sure the changes, if any, are not enough to make it a new version but I found the date change somewhat strange.
06-18-2021 04:32 PM
@Lotus7 wrote:Opening the respective FIR files in a FireOne editor shows a definite difference.
That increased file size does not necessarily have to be additional code. It could simply be comments and metadata.
06-19-2021 09:31 AM
That is a pretty poor compiler that passes the comments on to an executable.
They might have added some additional languages, though.
06-19-2021 02:21 PM
@kvbarkley wrote:That is a pretty poor compiler that passes the comments on to an executable.
That's how managed code works, though. Unmanaged code does not contain comments.
