09-04-2022
05:10 PM
08:25 AM
I have the 75/300 lense and a df-400 power extra flash. I shoot racing photography. I wonder what other lenses or flashes would help create sharper photos? Thank you!
09-06-2022 03:07 PM
I agree about the flash. Here that would not be allowed for health and safety reasons, but again I am not where the OP is... Given in their post below that their budget is 'minimal', and they are using a T6, I don't think the L glass you suggested is going to be a financially viable solution. They might be able to find a good used 70-200L MkI or MkII but the autofocus on the EF 70-300 IS USM MkII, which uses Nano-USM motors is blazing fast and it has better IS than the older L-series lenses.
09-04-2022 11:50 PM
If you have looked at the linked review I sent, and like the solution, can you please mark that post as a resolution, so that you will not continue to be contacted with repeated questions and solutions.
09-05-2022 06:45 AM
Hi, Trevor I cannot find a solution button for that post.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT, 600EX II-RT
09-05-2022 01:35 PM
Again, Demetrius, that comment about clicking the resolution button is NOT aimed at you. 😶
My comments, unless specifically addressed to you, will always be to the OP, in this case, CANDYN1251. Only the OP can mark an issue as resolved. You need to see less this as a conversation between that others are having with you, and see it as us all working to resolve the issue for the OP. That is why I state things you might think are obvious to you, but are likely not to them.
