06-08-2021
02:38 PM
08:56 AM
Hello I'm new to this forum. I have been using my Canon EOS T-5 for several years now and have literally taken 1,000's of pictures for travel baseball for years. Most of these games have been during the day time and I would use the TV mode and for the most part, these pictures came out awesome.
Now my son is playing college ball and most of his games are at night. I took some pictures using the same mode and some were ok, but just not great. I have been reading some of the comments on your forum for settings.
Can someone please give me easy settings to take actions shots? (my son is a pitcher, so fast moving action) on top of stadium lighting.
Would "AV" be my best option or "P" for an action shot in the dim lighting?
Also what setting should I use for people in the stands in the dark. Again I'm new to the night time picture taking, so any advice would be very much appreciated.
06-09-2021 02:21 PM
I scanned through the previous replies and here are the gems.
"... you may be better off using Av and ISO 400 to 800 witth your camera body."
Absolutely! Abandon full manual mode unless you just get that rare situation. Av is what most pro sport photographers use.
"The T7 will be more replacement than upgrade."
I agree don't waste your money.
"Rebel camera bodies have reputations for being good performers in low light. Save your money for an RP"
Here again I agree. R is the future EF/EF-S meaning Rebels is not. However if you are thinking just the next four or fives years the T8i is tempting ot the 90D. The 90D being on the top of the list as it is a fantastic camera.
06-09-2021 02:36 PM
Now for some settings I would use. Of course Av mode. ISO fixed at 800 but be ready to change it if need be. Up or down as baseball night games are usually pretty well lighted as someone mentioned. Using Av set your lens to its most open aperture which I suspect in your case is f5.6. This is pretty slow for action sports but its all you have. The Av is going to automatically set the T5 to its fastest SS it can. Use One shot do not use Ai-servo and just the center focus point.
Now there are two more very important things. One is location. Where are you are shooting from? On the field is best but most, all, high schools and colleges will not allow you to do that. So, bleaches it is but you will not get the best shots there with any camera combo. Secondly, and mandatory, is shoot Raw format not jpg. Never jpg! Get a good post editor. Canon offers the free to d/l DPP4 but there are others. I prefer Photoshop and Lightroom. Like I said if you want the best or good sports photos post editing is mandatory. All professional sports photos you see and love are post edited. All 100%.
With DPP4 the Raw conversion is automatic when you u/l to your computer so no input from you is required but the ability to alter and edit the photo is by far better. I have moved exposure 3+ stops before with Raw for example.
06-09-2021 02:41 PM
"... I'm using a 300mm lense on this shot."
You mentioned 300mm but you didn't say what 300mm lens it is? Is it this lens Canon EF 75-300mm f/4-5.6 III Lens?
This is what I would consider upgrading first before a camera. Although f5.6 isn't the best aperture for night sports it can work but there are a lot of much better lens choices available.
06-09-2021 02:48 PM - edited 06-09-2021 02:50 PM
" Photo taken 5/17/2021 @7:34 PM; 1/15, f6.3, 85mm, ISO 100. My T7 has the 75-300mm lens."
ALways a critic isn't there? But first just what is the subject? The pitcher or the infielder? The pitcher is OOF but closest.
A SS of 1/15 is way too slow to try and get sharp pictures at 85mm. Kick your ISO up to 800 or 1600. Remember doubling the ISO is just one stop I.E. 800 to 1600 is one stop. 100 to 800 is a nice gain and would get your SS up to more where it needs to be. ISO 100 to ISO 200 is one stop, ISO 200 to ISO 400 is one stop, and ISO 400 to ISO 800 is one stop, etc.
06-09-2021 03:05 PM
The pitcher is my grandson. EB, thanks for the critique. Not sure if any of the boys' travel games will be at night this summer. You have been most helpful. I do want to take a monopod for photos. As the photo being OOF, I was shooting freehand. Might expain that. Still learning. Do we ever stop learning? Again, thanks.
06-09-2021 03:19 PM
" Do we ever stop learning?" ![]()
Never, and in my case some things I need to learn is hopeless! You'll get there. You have to walk before you run so just keep shooting. In my case I need to crawl first.
06-09-2021 06:25 PM
I'm not so sure that you realize the reason why I suggested Av mode "for your camera body"or not.
It is not because I favor Av mode over M mode. Like I said, my recommendation would be to use M mode. However, the Rebel T5 has an unusual quirk, which probably shared by its' older siblings, the T6 and T7 cameras.
When you adjust exposure settings, you can only do so in whole stops, although the camera can automatically use 1/3 stops when the camera is in one of the automatic modes. The user can only set exposure in whole stops, but there is a work around.
The work around is to use Exposure Compensation, which is not available in M mode, but is available in Av mode. This is the reason why I made the recommendation to use Av mode, because of the camera model.
06-09-2021 07:06 PM - edited 06-09-2021 07:07 PM
jburch,
Google led me to some higher ISO images from your T5 and it still looks very acceptable at ISO 3200 and probably 6400 but try some different ISO settings and see how high you are comfortable going in terms of the ISO / noise tradeoff. You can definitely go above 800 with your camera and unless you are satisfied with images where your son is freezing in place prior to or after a pitch you are going to have to go with higher ISO at night or otherwise shutter speed will be far too slow to freeze motion. Even with a f2.8 lens, the exposure triangle isn't going to let you hit a point with low ISO and enough shutter speed in that venue.
If you aren't shooting in RAW, do so. That is a necessity to get the most out of your camera under difficult conditions and the same is true even if you move up to Canon's more expensive and capable bodies. If you aren't using RAW already, Canon has free software available for download (DPP) that will allow you to do post process work in RAW and then convert the files to jpg format for sharing.
Av (aperture priority mode) with fixed ISO was the best sports shooting mode available for many years and is what I always used with my 2005 era EOS 1D Mark II but that was because auto ISO wasn't available then which was a holdover from the film days.
Looks at the blogs and writings from sports shooting greats like Peter Read Miller and Scott Kelby and they have also embraced auto ISO as the mode of choice for shooting sports, especially under trying varying and night illumination conditions. The logic is simple, for low light sports you are going to use the widest aperture your lens offers the overwhelming majority of the time so it makes sense to fix that parameter. If you are shooting action, which is the majority of sports shots, then using a shutter speed too low for that sport just results in blurry images so you want to fix your shutter speed as fast as possible without forcing the ISO too high with the minimum shutter speed at least sufficient to freeze action for that PARTICULAR SPORT AND POSITION. You have now fixed two critical variables (aperture and shutter speed) of the three controllable variables in the exposure triangle.
So let ISO float so that the camera can adjust for a standard exposure by automatically adjusting ISO with respect to the best possible aperture and shutter speed values you have fixed. This is a very standard sports setup for current camera bodies with auto ISO capability which includes most of those produced in the last 10 years. It simply provides the best your camera will be able to do within the constraints of lens aperture and venue lighting.
For your next night game, set your aperture to the lowest number possible for your lens and try your shutter speed at 1/500 for a few shots with auto ISO and see what you get. If the ISO is at its upper limit and the image is still under-exposed, try dropping the shutter speed another step slower. If the ISO is reasonable at 1/500, see what it will do at 1/640. For example with night football, in the worst high school stadiums I drop shutter speed to 1/640, for decent I use 1/800, and for a great high school and many college I go with 1/1000. Lighting conditions always force compromises, your role is to choose the best possible compromise.
Before going to a new body, check to see how much better the T7 is at higher ISO compared to your T5 to see if it is a worthwhile upgrade. You may find that a different body is better. The primary ingredients for good night sports shots are an optimal location and a fast lens, without those two ingredients even a great sports camera body will be crippled in its ability to provide good images.
Sports shooting is already difficult because things happen so quickly and gets far worse at night due to lighting issues. And every venue has its own peculiarities. The regional softball playoff I shot yesterday is in a park that isn't well constructed for photographers. The outfield fence is very high and there is no high ground just beyond it but standing on my Pelican gear transit case gave me another foot of height which worked well. To get images of the pitcher and some of the infield action, I spent part of a few innings in the dugout entrance area shooting over the coaches heads while dodging the girls running out to retrieve fouls. It worked but it added complexities and distractions to shooting the game because my goal at sports events is to be as invisible as possible which doesn't happen when you are working in a busy area. The coaches and players were very gracious and wonderful to be around but my personal goal is never to be anywhere that has the potential for causing distraction.
Even in daytime, auto ISO is very useful. When I am at an event I will choose a shutter speed that will provide proper exposure at ISO 100 in the brightest part of the venue and let the camera adjust ISO as needed. I shot the third game in a regional softball series yesterday afternoon on a very bright and almost cloud free afternoon but shortly after the game started a thick cloud temporarily blotted out the sun and the camera increased ISO to 400 to compensate and this image of an inning ending throwout at first base were some of the very few at the game not in the ISO 100-160 range. Moments later the sun was coming back out dropping the ISO back to 200 and then 125 for a slide into second on the way to another run.
Capturing images in RAW format provides files which are pretty tolerant of over/under exposure and two stops of adjustment in post would have worked pretty well but I prefer getting things as close to perfect as possible in original and auto ISO is a big help in that department.
Rodger
06-09-2021 07:19 PM
Waddiizzle,
I haven't shot with a T5 but doesn't custom function setting 1 allow you to set it to 1/3 or 1/2 stops for aperture and shutter speed? Canon manuals aren't exemplars of excellent technical writing but from the T5 manual I looked at online that appears to be similar to what other Canon cameras offer as an option under Cfn 1.
Rodger
06-10-2021 01:32 AM
@wq9nsc wrote:Waddiizzle,
Rodger
Yes, you can set the increment to either 1/2 or 1/3 stop. But, that only seems to apply to the camera's automatically set exposure values and exposure compensation. .All manually entered exposure settings were made in whole stop increments on my T5, and I would expect for the T6 and T7 to behave the same way.
As long as the camera has control over at least one leg of the Exposure Triangle, exposure can be controlled and set 1/3 stop increments, but it is done automatically for you. Your manually entered values are in whole stops, but the camera's automatically provided setting will be in 1/3 stops.
I could only enter ISO as 100, 200, 400, 800, etc. The same was true for aperture and shutter speed. You could only manually enter whole stop values, while the camera provided its' setting in 1.3 stop increments.
This behavior isn't really an issue in any shooting mode, not even in M mode. In M mode, just use ISO Auto for more precise control over the final exposure setting.
