EOS Rebel T3i Write Protect Error
Bluecollarcowbo
Hello, I have a canon t3i rebel that I have used for quite some time and just earlier this week, I got an error message on my camera saying that my memory card was protected and that it wouldn’t let me take photos. The switch wasn’t down so I thought maybe this was the card itself so I got a new one. The same exact message showed up for a new card, I checked for debris in the card slot and could not see anything. Thanks.
16 REPLIES 16
I’ve had it for about 5 years.
Are any pieces of the old SD Card broken off in the card slot. Inspect carefully with a flashlight and check the original SD Card for any broken pieces. If clear then the fault is with the camera.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
normadel
Do you only have one SD card?  Trying another one will tell you what's what. A 16 or 32 GB card is cheap.
Unfortunately I have tried 3 brand new  ones and unfortunately everything said the same thing.
kvbarkley
You have never said whether you have inspected the inside of the slot. Take a long, thin tool, and try to exercise the little switch that engages the write protect tab. It may be stuck
Thanks for the tip, what does the switch look like
 this is what the inside looks like, there’s a little black lever on the left hand side, but I assumed that was just the lever that eject the card
Friends and Family
