11-02-2022 05:28 PM - last edited on 11-04-2022 08:05 AM by Danny
11-02-2022 05:47 PM - edited 11-02-2022 06:14 PM
Hi. Are you using this lens with a lens hood, and if so what exact model is it? To me, it looks like you have vignetting from the lens hood, which is surprising for using a telephoto lens.
11-02-2022 05:33 PM
Hello Icparker welcome to the forums. Is this a new problem you recently noticed. What lens are you using with your camera. Does this problem appear in live view too. You have a picture attached showing the rear LCD.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
EOS 40D & 5D Mark IV
430EX III-RT & 600EX II-RT
11-02-2022 05:43 PM
I am using Ef 100-400 canon zoom lens. I only see the dark corner coloring when I view the picture looking through the viewfinder. The picture has beff RF n already taken.
11-02-2022 05:50 PM
I was thinking the same thing too. I haven't seen a telephoto lens with vignetting like that before.
-Demetrius
11-02-2022 05:51 PM
I have, when the wrong lens hood is used.
11-02-2022 06:03 PM
I noticed some lens hoods for different lenses fit fine but you'll have vignetting.
-Demetrius
11-02-2022 06:11 PM
FYI, I wasn’t using a lens hood.
11-02-2022 06:13 PM
Yes I have, called canon they said asked the community
11-02-2022 05:54 PM
Which EF 100-400mm lens Canon has released 2 different models and each have a different lens hoods made for them. You can find the full name of the lens on the outer silver or white ring of the lens after the Red ring.
-Demetrius
