08-27-2024
10:03 AM
10:09 AM
This is driving me nuts! I found a video in a different language years ago, but now I cannot find it. How do you turn the grid feature on the SL3? Thanks!
08-27-2024 10:29 AM
To see all the options you need to be in P mode. The grid is set with function 4 menu. You may need to be in live view since it does not apply otherwise.
08-27-2024 10:11 AM
The manual is your friend. I searched for "grid"
Since it is not starred, it should be available in every mode. But if you don't see it, switch to P.
08-27-2024 10:27 AM
I do not have a single setting that has 7 choices. I have read the paper manual at least 3 times and there is nothing about a grid.
08-27-2024 10:29 AM
08-27-2024 10:37 AM
OMG! Thank you. Shows up with 3 choices- then live- 4 so difficult. Thank you!
