12-19-2023 04:04 PM - last edited on 12-20-2023 08:56 AM by Danny
I have a new EOS RP. The maximum resolution that I'm able to set on the camera is 3,880x2590 even though the specs for this camera are a maximum of 6,240x4160. I would appreciate any help with this issue.
12-19-2023 04:40 PM
Looks like you have the Image Quality set to Medium with an aspect ratio of 4:3 (closest values to the 3880 x 2590 you mentioned).
See pages 583 and 584 in the User Manual. Always best to ensure you're capturing the highest quality, so set to Large (Fine). Also, for maximum quality, capture in RAW. For added flexibility, capture in RAW plus JPEG.
12-19-2023 04:39 PM
Welcome to the forums.
Exact which menu setting are you trying to adjust? Image Save Format?
Do you have a formatted memory card installed in the camera?
12-19-2023 04:40 PM
12-19-2023 09:28 PM
Thank you for your response. We tried all combinations of Large/Raw/JPEG, but the highest resolution we can get is 3880x2590. We researched your mention of "aspect ratio" and discovered we were sold a "RF-S lens with the camera body. Apparently, it is designed for the R10, which has "smaller sensors than the RP...so the lens will 'crop' heavily" on our camera. We believe that what we need is a "full format" RF lens, so we'll try that. Thanks again for your help!
12-19-2023 09:58 PM
Yep, that makes sense. I hadn't thought about crop-mode which will happen when using any RF-S lens on a full frame R-series camera. Glad you got it all figured out.
