04-16-2021 09:51 PM - edited 04-20-2021 05:24 PM
When the power dial is set to "off" the camera powers "on" by itself and flickers "on" and "off" until the battery dies. I tried updating the firmware and removing all accessories, however the issue still persists.
04/20/2021 UPDATE (for Canon techs):
- The issue is present with / without the accessories (i.e. lens) attached.
- Tried removing the battery for a few days, and putting it back in. Issue still persists.
- If you insert the battery back in (with the SD card), it starts flickering again. Likewise, if you press the shutter button, it turns ON even though the dial is OFF.
- I've tried hard resetting to factory defaults. Didn't solve the problem.
- Updated firmware, still not solved.
* Will be sending it in for repair. Thank you to everyone who responded.
Video #1:
Video #2:
01-10-2023 01:02 PM
Maybe Canon hacked in (since I hadn't disabled wifi settings) and did a firmware fix for this thing...😂
04-17-2023 01:11 PM
Hi I am having this same problem. How did you resolve the problem? Or what was the outcome?
08-14-2023 11:57 PM
Unfortunately, I've been hit with this issue on my RP too. All of the following hasn't helped: Disabling wifi, running the latest firmware, doing a factory reset, getting new genuine canon battery. I will get a quote from Canon for a repair.
08-25-2023 11:35 AM
I have Exactly the same problem
08-29-2023 07:10 PM
Hi. My camera has same issue. I'm pretty disappointed in Canon on this one. There is a solution that costs nothing. That is, do not shut down, let the camera automatically sleep. Probably the most radical solution is to switch to another brand of camera.
02-08-2024 10:59 PM
Yes, and me too. Canon EOS RP, purchased in UK. Not had a chance to explore behaviour fully, but will try some of the suggestions on this page.
04-24-2024 02:02 AM
Just adding to the topic that I have the same problem and no WiFi, Bluetooth. Obviously something wrong when the screen flickers. Any luck with repair?
07-07-2024 04:08 AM
I have the same issue with my RP. Turned off Wifi, Bluetooth, updated firmware to latest. Take out SIM card, remove lens. It will randomly choose to wake up after turning off. Sometimes turning the on/off switch to off will have no effect, a few flickers later and it is still on. With the lens on it will drain the battery in a few hours as everytime it flckers, the aperture diaphram is activated. The most annoying part is after a day or two, it could cure itself and everything is back to normal. Took it to Canon service and they said could not reproduce the problem. I am now using the battery compartment door as the on off switch . I have been using Canon cameras for thirty years, very disappointed at the build quality.
07-07-2024 09:55 AM
Greetings ,
As you are resurrecting a 3-year-old topic, we will need some additional information.
What firmware version are you running?
Do you have any third-party accessories connected to your camera? Lens grip, adapter, flash, etc
07-07-2024 03:33 PM
It’s running 1.6.0 . Removed lens and all accessories. Genuine Canon battery, tried two different ones. Turned off wifi, Bluetooth, factory reset numerous times. Same behavior, flicker after switch is off and goes back to on. If lens attached, battery drained much faster, each time it turns itself on the lens aperture gets activated.
