06-10-2026
04:42 PM
04:56 PM
SamanthaW
After years working perfectly, my camera suddenly gave glitches and froze when recording after 1-2 seconds.
I updated the firmware in hopes to fix the problem but now the lcd screen appears glitched even when not recording.
I bought this camera when it was released, and I have take extreme care of it, never dropped, and never got water on it.
I am pretty disappointed that Canon does not want to be responsible for what clearly is a factory defect that has affected a lot of R8 and more R cameras.
But if someone in the community have the knowledge to fix the issue I´ll deeply appreciate it.
Even thought the visor and hdmi out work properly, whenever I try to record, the camera freezes again, and after half pressing the shutter button a couple times, it reboots. But can not be used for anything really. I was hoping to film a shortfilm with this camera but is literally impossible. I want to bring visibility to this problem, and clarify that I am from Mexico, Puebla.
06-11-2026 08:28 PM
It works through HDMI but the glitch after recording a few seconds comes again, with hdmi or the viewfinder, is impossible to record!
06-11-2026 08:32 PM
It is really sad, and totally destroys my confidence in R line cameras, specially since the glitch happen from nowhere, and with just a few years of casual use. I loved the specs of the r8, and the rf lenses, but even if i get to repair it I don't know if I can trust it again.
06-11-2026 08:52 PM
I also have an R100 and it operates flawlessly. The "trust" issue is one I share with you vis a vis the R8. With luck this will be resolved positively.
06-11-2026 10:13 PM - edited 06-11-2026 10:14 PM
Will the camera turn on and sit idle without the LCD screen malfunctioning?
Have you tested with a different freshly formatted full size memory card in the camera?
I didn't see any mention of this in the thread.
06-12-2026 10:10 AM
""never do a FW update on a malfunctioning camera"
*Unless* the firmware update specifically says that it addresses the issue. After all, that is often what firmware updates are *for*."
There is a huge difference between a malfunctioning camera and a FW update to camera ability (languages) or new lenses, features, etc. It surprises me that you do not realize that.
06-12-2026 10:14 AM
"^^THIS^^"
Not just bad advice THIS time but horrible advice.
06-12-2026 10:29 AM
Say what??
06-12-2026 06:42 PM
The camera turns on and the lcd dims when idle, but even with the viewfinder, after recording a couple seconds the glitch stop the record and crashes the camera. Yes I´ve tested multiple cards no luck.
06-12-2026 07:09 PM
Roger on that. It's either going to be the LCD or the main board, probably the LCD <<<<
