02-26-2024 08:10 AM - last edited on 02-26-2024 11:28 AM by Kristoff
Hi all!
How can i make camera power supply from external source? For example, if i want to do some long videos i want to do with socket power or power bank?
02-26-2024 12:17 PM
It can. 😃 You can either power the camera, or charge the battery, but not both at the same time.
02-27-2024 08:33 AM
Your battery or charger has to have a USB-C PD port that outputs 45W. See the following article that references this (specifically for the original R6, but the spec hasn't changed):
https://support.usa.canon.com/kb/index?page=content&id=ART177807
02-26-2024 08:22 AM
Greetings ,
If you're indoors, Canon has a USB C /ac adapter.
If you need something for the outdoors, a USB- C PD or v-mount are your best options.
02-26-2024 10:52 AM
@aquagen wrote:Hi all!
Are you looking to power the camera using the USB port? I don’t think the camera allows for that. You can charge batteries using the USB port, but I do not think you can use the camera at the same time.
You might want to look into the Canon AC adapter and DC battery eliminator.
02-26-2024 12:17 PM
02-27-2024 05:03 AM
Thanks.
OK, one options is ac adapter.
What is USB- C PD? Can i do it with ordinary power bank (like 20000mah)?
02-27-2024 08:33 AM
02-27-2024 11:02 AM
@Stephens post is correct. My PD is 45w, 9.0v and 3A. The R5 C is currently the most power hungry device in Canon's MILC line up. 😀
Don't skimp. Mine fits in a shirt or coat pocket. They also sell small V-Mounts now with a belt clip. Make sure you use the cable relief attachment. If the R62 doesn't come with one, put the camera into a small rig cage. You will bump the connection, pull it out unintentionally etc unless you are on a tripod.
