11-06-2024
01:39 PM
01:42 PM
hello, why when i shoot with my canon R6 II on Clog3 on FHD120 FPS, Shutter 250 , ISO 800 , F2.8 , video is 2-3 exposed and when i replay it on my laptop any dark backgroud looks grainy ? while when i use 4k 60FPS it seems a less grainy background.
11-08-2024 06:16 PM
Hello Mohamed-Azmey,
Noise may appear when Canon Log is [ON] and [Peripheral illumin] is enabled. Let's check to see if that is the case here. Noise may become more noticeable if you enhance the contrast when color-grading your movies. With Canon Log, skies, white walls, and similar subjects may be affected by noise or uneven gradation, exposure, or colors. Horizontal banding is more likely to occur when recording somewhat dark, flat subjects. This image noise may even occur at relatively low ISO speeds around ISO 800. Try recording under brighter conditions and adjusting brightness in color grading. Although dynamic range is narrower at ISO speeds lower than ISO 800, noise can also be reduced by recording this way.
