07-07-2024
04:07 PM
08:55 AM
Folks,
When shooting concerts that are broadcasting from the stage to big screens at the venue (or possibly to remote capture fro internet viewing), I keep winding up with lines running through my photos, much the way one would if they took a photo of the big screen itself. Shooting with an R6 Mark II and the problem occurs irrespective of lens attached. Based on my assumption that the broadcasting of the image to the big screen is the likely cause, I have tried to shut off all remote connections on the camera but the problem persists. Ideas what may cause this or how to remedy the situation?
07-07-2024 04:11 PM - edited 07-07-2024 04:12 PM
Try enabling the anti-flicker settings. The giant screen could be acting like a giant light source.
You might also try reducing your shutter speeds.
07-07-2024 05:16 PM
Hi and welcome to the forum:
Yes, the banding you are observing is very likely caused by interference patterns between the frequencies of the screen projection system and your camera's shutter. As my respected colleague Waddizzle has noted there is a feature called Ant-Flicker but if that does not work , try changing your shutter speeds to a lower value.
07-07-2024 07:14 PM
Thanks for both the prompt and informative reply. Will give it a try at the next show!
BTW, happens with my R6 but not my 5D Mark IV. Different bluetooth and NFC in each body?
07-07-2024 07:15 PM
Thanks, Trevor. Appreciate the welcome and the validation of the prior response.
07-07-2024 07:31 PM
Comm settings shouldn’t matter. This seems to be all about exposure settings and shooting conditions.
07-07-2024 07:35 PM
“ BTW, happens with my R6 but not my 5D Mark IV. Different bluetooth and NFC in each body? “
What is the shutter mode setting in the R6?
07-07-2024 07:39 PM - edited 07-07-2024 07:47 PM
Agree with the above (Trevor and Waddizzle). On my R5 C this feature is called clear scan. However, it only applies to video mode and was introduced in v1.0.5.1. Although it states for CRT monitors (in the manual), I saw it demonstrated on a video screen at a live performance. For stills I'd be in the same boat. ☹️
07-07-2024 07:39 PM
Rotate the body to landscape and it will be horizontal banding. Are you using the full electronic shutter?
