EOS R6 MKII not working after latest firmware update
gabrielt24
I updated the firmware. My camera shows the firmware is updated. Now when I start shooting either single or high speed multiple shots successively the camera says busy and it takes about 3 seconds for it to process the image and I only get 1 image out of all the clicks I did. Also I get some blurry images even though I set speed at 1/1000 sec. It seems like everything is out of whack How do I fix this? Thanks
I have both bodies. Resetting the camera did fix the problems. Thank you
9 REPLIES 9
rs-eos
Applying firmware should have reset the camera settings, but it would be best to reset the camera back to factory defaults.
Ricky
I did reset the camera back to factory setting. That did not help. Thanks
After resetting, the busy message went away but I am only able to shoot single shot, no high speed multiple shots.
Do you have the appropriate setting enabled? Note that by default Shoot Continously defaults to "Low speed continuous".
Refer to page 291 onward in the User Manual for how to set burst mode settings.
Ricky
Multiple posts from this user.  Same description.  One post is for the R7, the other is R6 mkII.  Which body are we troubleshooting @gabrielt24?
Thanks
That fixed the problem. Thank you
Please update this topic to select the answer as the solution. This helps other readers know that the issue has been solved. Thank you.
Ricky
Thank you for this clarification.  I believe my colleague Ricky provided the solution.
Friends and Family
