EOS R6 Lines on the sides of photos
jr113
I am a fairly experienced EOS user but am a bit perplexed. WIth an EOS R6 and RF 24-240 lens, on many photos I get lines around the edges (see example). I am not sure why these appear, but they do not seem strictly correlated with focal length or aperture. Any suggestions? TIA!AO7A2935-4.jpg
Peter
You are using Adobe and its lens correction version 2. Use version 1.
Nothing wrong with the camera.
Possible to recreate by choosing the wrong scale in dt.
7 REPLIES 7
Peter
jr113
Thank you!!
emilycavey
Hi, having the same issue, did you ever figure out what the problem was?
The problem in Lightroom is the profile. AutoScale is set to false when it should be true. The profiles are in lcp format and named after the lenses. Just open with a text editor and change yourself. Or use v2 instead of v3.
kvbarkley
VIP
VIP
An Adobe lens correction issue. Just where are you seeing this?
ctitanic
Rising Star
Pardon my ignorance. Where can you find the profile files?
Frank
Gear: Canon EOS R6 Mark I, Canon 5D Mark III, EF100-400 L II, EF70-200 f2.8 II, RF50 and few other lenses.
Flickr, Blog: Click Fanatic.
User/Adobe/Camera Raw or something like that. Or just use the search tool in your OS.
Avatar
