05-17-2023
06:03 PM
08:38 AM
I just bought a an R6 and am working through and learning the menus. The image on the rear screen seems to only fill 4/5's of the screen. It seemed larger a day ago. Have I touched the wrong menu button?
Just curious?
Thanks for any help.
Tom Heiden
05-17-2023 06:55 PM
What mode are you in. Full Auto doesn't display all of the mention options available. Unlike the creative zone (M, AV, Tv, P & Fv) modes.
05-17-2023 08:00 PM
Thank you very much for the reply. My fault, I didn't explain this properly. I am in FV mode (which is incredible). The actual LCD screen display - menu or image - doesn't seem to be filling the entire LCD display screen. Displays are centered but the media, menu or image, doesn't go corner to corner on the screen. There is a black border around the media. Seems like wasted real estate.
Again, Thank You !
05-17-2023 08:01 PM
Reset the camera to factory default. To see if that fixes the problem.
05-17-2023 08:04 PM
Thank You
05-17-2023 08:25 PM
Did that correct the problem. If not I can ping an R6 owner to assist you further.
05-17-2023 10:39 PM
My first reaction is to check P8 of the Red Menus, VF display format. I suspect you may find that is set to Display 2, which has that effect - to get the full screen set to Display 1.
