EOS R50 SD card stuck.
MasonSmith
Last night I put my sd card back into my EOS R50, and now every time I try to pull out my SD card it just won't let me. I don't know what to do for right now. Can someone give me some solutions to this issue?
The card slot uses a push lock spring retention system.  In rare circumstances, they can bind or become jammed.  To release you just need to push the card in gently and lightly.  Do so with even pressure.  If the card will not release and pop out, you'll need to send the camera to Canon for service.  Please do not try to take it apart yourself.
1 REPLY 1
