03-05-2024
09:06 AM
09:08 AM
i read in the manual for the EOS R5 camera page 314 that "recording of 8K and 4K movies is not supported with RF-S or EF-S lenses. I am unfamiliar with S lenses and all lenses. I am about to rent the R5 body with CH- Canon RF 24-105mm 2.8 L IS USM Z lens. Will i be able to shoot video with this lens?
03-05-2024 09:53 AM
As long as the lens does not say "RF-S" on it, you are good.
'-S' lenses refer to lenses designed for cameras with APS-C sized sensors - like the R7 and R8. Since the sensors are smaller, the lenses are designed with a smaller "sweet spot". While a '-S' lens will fit on a camera with a Full-Frame lens - like the R5 you are interested in - the camera will limit the image or video to the sweet spot of the lens, i.e., it will not utilize the whole lens area. I am guessing that 8K and 4K movies use an area of the lens larger than the size of the APS-C sensor, so the camera will not let you use one of these lenses for this kind of video.
03-05-2024 09:53 AM
07-23-2024 04:15 PM
How do you perform unlimited video recording with canon r5?
