EOS R5 Mark II: BBF and AE Lock
thegios
Enthusiast
I have triple BBF configured
- SHUTTER: Metering Start
- AF-ON: Metering and AF Start
- *: Metering and AF Start but with subject detecnion OFF
- FOCUS POINT SELECTION: Af with eye control
How do I lock exposure now?
I am asking because people keep on telling me that by half pressing shutter the exposure is supposed to be locked, but this is not the case in any metering mode and/or shooting mode and/or focusing mode.
Thx
21 REPLIES 21
After some tests, probably I have an answer to QUESTION 2: metering is taken at center on the subject, but when the subject moves the focus is still on the subject but metering is still taken at center and as a matter of fact changes whiel subject moves off center
I still don't have an answer to QUESTION 1
For your QUESTION 1
The new ability in the EOS R5 Mark II to choose to bias the evaluative metering to the subject or not works like this.
The camera must be set to evaluative metering, subject detection cannot be set to NONE
In such case the detected subject in the frame will be the most important part for the exposure system, even if other parts of the frame are in-focus but not a subject. You can imagine a person stood in a doorway, the face is the important subject, even though the door frame is also in focus.
When Detect priority AE while AF is off, then all the in focus AF points are considered as being important areas for the metering. This is also the effect when subject to detect is set to none.
Hope that helps.
Brian
This helps indeed, because I had the same interpretation: to me there is a distinction between SOMETHING in focus and a SUBJECT in focus, where SUBJECT can be a person, an animal or a vehicle. I had dis discussion with someone else in an other forum who would say: why a chair in focus should not be a SUBJECT, and to me the reason is that otherwise Canon would not have made a menu option for SUBJECT detection on/or where you have a limited list for subjects (person, vehicle, animal).
So according to waht you say:
  • EVALUATIVE + "Detect priority AE while AF" ON + "Subject to detect" ON: metering on SUBJECT
  • EVALUATIVE + "Detect priority AE while AF" ON + "Subject to detect" OFF: bias toward whatever is on focus
  • EVALUATIVE + "Detect priority AE while AF" OFF + "Subject to detect" OFF or ON: bias toward whatever is on focus
Agreed that's how I read it.
And for good measure when you use the AF areas with the padlocks they force subject detection to none and also whole area AF tracking off, so this setting is not relevant for them either.
Brian
"when you use the AF areas with the padlocks"
What do you mean here?
The EOS R5 Mark II has four additional AF areas each with a padlock in the lower right corner.
Check the second screen illustration on this page of the EOS R5 Mk2 manual
https://cam.start.canon/en/C017/manual/html/UG-04_AF-Drive_0060.html
These "padlocked" AF areas also force subject to detect to none and switch off whole area AF tracking, so that these areas will work the same as the ones in the original EOS R5. But since they have no subject then the "Detect priority AE while AF" setting is not used, simply the active focus points.
Brian
Oh yes yes, I know... Apologies but couldn't associate "padlock".
Thanks again
jeffn54
I have not tried the specific configuration of the BBF button you have defined here. But, I found in most if not all cases I can lock the Exposure with the * button on the back.
You are correct that the * button locks the exposure normally on most cameras.  However the OP mentioned that they had reconfigured their * button to work as an additional focus button with different settings to the AF-ON button, and in-doing so needed a different way to access the AE-lock function.
Brian
KFSC307
I guess the thing that confuses me is that despite one shot, with spot focus, and the AE lock after focus set up on my R5M2 is that if I lock the focus, and then recompose, the meter keeps moving along reading wherever I am pointing the camera. I see no evidence of anything being locked. I came from the Nikon environment and when I chose AF/AE lock, it locked the AE where I focused on the subject, and the meter did not twitch at all when I recomposed.
I realize that by shooting in manual that it makes little difference as to AE lock, but I find it annoying that you cannot get clarity even when choosing AE lock after focus. Maybe I am doing it wrong, but so far, it makes no difference. It is like an option that does nothing.
