EOS R5 Cannot change aperture in FV mode
Bazsl
Rising Star
When in FV mode on my R5, I can select Av using the quick control dial but when I turn the main dial the exposure compensation changes, not the aperture. Tv and ISO work as they should. How can I fix this? Thanks.
1 REPLY 1
Waddizzle
Do you have any custom control programming causing the issue?  You could try resetting the camera back to factory defaults.  This guy explains which button should do what.
https://youtu.be/85T--N0TnUI
