EOS R5 Blurry Pictures with Flash
Andreacamarenap
I use my EL-1 on camera and I am getting blurry pictures... my shutter speed is 500.
2 REPLIES 2
deebatman316
Are you taking pictures in low light or low contrast situations. If so the camera may be UNABLE to lock focus that's why the camera has a built in LED AF Assist Beam. But when a speedlite is being and the ambient brightness is low. The speedlite will assist the camera's AF system using Intermittent Flash Firing the "IR (Infrared)" (not really IR just a red grid pattern) AF Assist Beam DOES NOT WORK ON ANY mirrorless camera system. Please post some pictures in the forum. What lens are you using. What settings are you using ISO & Aperture. You only listed a shutter speed.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
rs-eos
Can you post an image along with what your camera settings were?
Since 1/500s is faster than the sync speed, assuming you had high-speed-sync enabled.  Does the metadata for the captured image show it was indeed take with 1/500s?
Ricky
