08-22-2019 09:56 AM
08-23-2019 06:37 PM
@johneos1 wrote:Hi Tim, if there is no other way to fix this problem I will ship the camera in for repair. I have the Canon EOS R since 12/2018, and this will be the second time the camera has been sent in for repairs. Not a good start for a new camera, what is the determining factor for replacing R?
Appricate your help in this matter. 🙂
Thank you,
John Mickler
Exactly what memory card are you using? Brand, Model, Capacity? UHS-I or UHS-II? Full size SD or micro-SD?
08-22-2019 04:08 PM - last edited on 09-10-2019 02:07 PM by Renee
Hello johneos1,
I understand that this has become a problem with your EOS R and for that we apologize. This is a strange issue to have occur and I know you'd like to resolve this as quickly as possible. We recommend setting up a service ticket on the Canon web site to get started with the service process.
You may fill out an online repair request form at the following link to setup your repair using our online service.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
08-23-2019 01:14 PM
Thank you,
John Mickler
08-23-2019 06:37 PM
Thank you,
John Mickler
08-23-2019 07:56 PM
05-26-2021 10:30 AM
I found the protected images issue a result of the Multifunction Bar. Double tapping the bar can randomly protect image if set to protect. Just go into the Customize M-Fn menu and turn some or all the features off.
