12-27-2020 01:59 PM
Help! Bought a used EOS R. Worked well until I put about 30 stills on a Lexar SD 256 mb / 10.0mb/sec card, now every time the shutter releases the camera freezes, card read/write indicator flashes randomly and I get either "Err 110" or "Err 111" and have to turn it off and back on to reset, but it does it again. And no image is capped.
12-27-2020 06:32 PM
Perform a full camera reset and test with another brand card.
12-27-2020 07:01 PM
@Louden99 wrote:Help! Bought a used EOS R. Worked well until I put about 30 stills on a Lexar SD 256 mb / 10.0mb/sec card, now every time the shutter releases the camera freezes, card read/write indicator flashes randomly and I get either "Err 110" or "Err 111" and have to turn it off and back on to reset, but it does it again. And no image is capped.
Say again? What size memory card you using? If your card is only 256MB and operates at only 10MB/sec, then that is the problem right there.
12-28-2020 04:13 AM
My bad. SHould be GB not MB
12-28-2020 06:48 AM
@Louden99 wrote:My bad. SHould be GB not MB
A 256GB memroy card with a write speed of 10 GB/sec does not exist, and 10 MB/sec is far too slow.
Which Lexar model SD card are you using? Is it a full size SD card?
12-29-2020 05:01 PM
Have a different one coming to test it out. But this is the one I was using. Brand new.
12-29-2020 05:13 PM
Okay. I like to use Sandisk Extreme Pro 64GB cards, myself. They cost less, less $20 most of the time. Failures don't cost an arm and a leg.
