05-19-2023 03:44 PM
I took about 100 photos this morning and now there are only 8 on my camera.
Is there any way to recover these? Or do we think they are gone for good??
Does anyone know any reason that these photos would not have saved?? I'm super upset about it 😞
05-19-2023 06:53 PM
Are you using Full Sized SD Cards or Micro SD Cards in an adapter. Is the write protected switch turned on. This will prevent the camera from writing to the SD Card. Also what size SD Card are you using.
05-20-2023 05:47 AM
Did you format the memory card? Depending on what brand memory card you got some come with recovery software for a year or so and then you have to pay for it after that. Also in your settings there is a way to set it so your images are protected. This is for the Canon M50 Mark II but it will work on the M50 as well, I went through my M50 and made sure for you. https://support.usa.canon.com/kb/index?page=content&id=ART178458
05-20-2023 08:04 AM
It is a 128 gb sandisk It is not a micro it is the standard size that fits into the camera without anything special...
05-20-2023 11:37 AM
I just want to confirm that your using the original M50 not the M50 Mark II. Older cameras seem to have issues with 64GB or larger SD Cards. The cameras will work correctly with 32GB or smaller SD Cards. Despite saying SDXC (64GB or lager) is compatible.
05-20-2023 03:20 PM
Are you only looking in the camera? Have you put the memory card in a card reader in your computer and browsed the card to look for the files you seek?
05-20-2023 07:48 PM
I run, 2 256gig, a 128 gig, a 64 gig and a 32 gig and have never had problems with any in my M50
05-20-2023 07:55 PM
I was stating that some cameras have problems with large cards. Not all cameras have problems with large cards. For instance the Rebel SL3 and T7 have problems with 64GB (SDXC) or larger SD Cards. I just wanted the OP to test out a smaller SD Card to see if the camera would work correctly. Also 32GB SD Cards are SDHC not SDXC.
05-21-2023 08:12 AM
Yes - i looked on my computer and also my phone. They are not there..
05-21-2023 08:13 AM
I have not formatted the memory card. I printed the instructions for this and will do so immediately. Does this prevent this issue from happening again???
