02-12-2025
11:57 AM
08:09 AM
I'm photographing a friend's paintings and having a really hard time with exposure. I have an EOS M50 Mark II. I've tried all sorts of experiments, none have worked. For the purpose of this post I'll consider just one. I have a painting sitting in indirect sunlight near a window. I'm using P, evaluative metering, filters off, auto lighting off (disabled), picture style standard 4,2,4,0,0,0, white balance AWB-W 0,0. The shot was f/5.0, 1/60, iso 320. Brightness +/- 0. The picture comes out dark and I need photoshop to bring it to life. Here's the rub. I take a picture with my iPhone and it comes out perfect. Any help greatly appreciated. (I've had trouble with exposure in other contexts as well and wind up setting brightness high, but for this shot increasing brightness takes away the subtle colors of the rose) Here's the two shots: iPhone photo
M50 (reduced size to upload)
02-12-2025 04:23 PM
Hello, Dennis, and welcome to the forum!
Here is a screen shot of a comparison of the EXIF data from both shots. Hopefully you can see why the iPhone image is better in this situation. Compare aperture, shutter, and ISO. The phone was able to have a very wide aperture of f/1.5 (more light) vs f/5 (less light). The best you can do with the 18-150 is shoot closer to 18mm to get f/3.5 (more light), but I am not familiar with how the M50 II works with the EF-M 18-150mm f/3.5-6.3, that is, how it handles the wide angle lens correction.
You can either try increasing exposure compensation as Demetrius suggested, or add more light. I prefer more light, but that's not always possible. Since you mentioned picture style settings, I'll assume you are capturing JPeG. Try capturing in Raw and you will have more control in post to adjust exposure. If you don't have a dedicated Canon Raw editor, download DPP 4. It's not the most robust, but it handles Canon Raw the best and will export to PS. If you go that route, be sure to load correction data for your lens. It's a feature in DPP so just click it and select your lens from the list.
Newton
02-13-2025 09:11 AM
Your camera sees things in gray. So any very bright colors will fool the metering system. Then cause it to underexpose. Your phone works differently it meters with color. That’s Color Matrix metering. Canon doesn’t use this.
02-16-2025 09:08 AM
The problem is the white snow fooling the camera’s metering system. If the camera sees white it will underexpose. The camera’s metering system sees gray and it will try to make everything that way. Your phone uses Color Matrix Metering. It takes color into account when metering. Your camera cannot do that. Your phone is using what’s called Computational Photography. No standalone camera has that. So to fix the underexpose use Exposure Compensation. I don’t believe anything is wrong with your camera. Most cameras will underexpose in that type of scene.
02-12-2025 04:05 PM
Thanks. I ordered one. But not sure how to use it when I get it.
02-12-2025 10:48 PM
AT one time they had a good article on how to use it.
02-12-2025 04:23 PM
Newton
02-12-2025 09:33 PM
Thanks! That explains a lot. And light, yes, in full sun we can get it right, but we don't want to lay the paintings out in the snow... Thanks again
02-13-2025 08:33 AM
What I don't understand is why the camera didn't adjust the shutter speed down to get the proper exposure. I've since been playing with M mode and f/3.5 (as you suggest) and slowing the speed, and I can get more light and again, get the details washed out of the picture. What's the difference between exposure compensation and pushing the shutter speed down? (I can use a tripod as the art isn't going anyway.)
02-13-2025 09:22 AM
Exposure compensation can adjust shutter speed, Aperture or ISO. If you have a particular reason to fix any of those, it is best to do it yourself.
02-13-2025 09:46 AM
I suspect the difference is in how the scene is metered and how that metering information is used. The camera is using computational photography, its firmware. The camera has it, too, the photographer.
As I compare the two image, there is one thing that sticks out. The metering. If I assume that both images were metered at or near the bright, white area in the center of the flower, I see an obvious difference in the shade of the white. The phone has rendered the area pretty much as white. The camera has rendered the area more toward 18% Gray, which causes the entire scene to look darker.
The phone is able to calculate that exposure compensation is needed. It is able to accurately estimate what the final captured image will look like with these settings. If it thinks it is too dark, then the camera will add some exposure compensation to the settings before it captures the image.
The photographer is able to something similar by enabling a setting called ExpSIM. This setting enables the camera to present an image to the photographer that simulates the exposure settings. If you feel the image is too dark or to light, then you can tweak the final exposure using compensation.
02-13-2025 10:27 AM
Thanks!
02-13-2025 02:50 PM
I had a typo. The phone’s camera uses computational photography. I left out the word phone.
Computational Photography means that it uses AI to make your photos look better. The end result is not an exact match to what was originally captured.
02-13-2025 10:52 AM
Take the picture in RAW mode and edit it afterwards. Slight underexposure is ideal for RAW.
If you want it to come out right out-of-camera, use exposure compensation. Or work in M mode entirely. Your camera should be on a tripod, your ISO should be 100, use a zoom of about 50mm, close the aperture to f/5.6 for better crispness and then adjust the exposure time accordingly, you'll probably need 1/15 or longer. Use a 3-second time delay to avoid camera shake.
