EOS 90D won't focus or switch off unless I pull the battery
Db59Kjb63
Hello
I have a Canon 90D camera and it has been fine since i bought it a few years ago.
Now for some reason after taking a few shots , it will not focus and will not switch off , i have to take the battery out to switch it off .
When i put the battery back in it is fine for a few more shots then the same thing happens again ,i have tried this with a fully charged geuine canon battery and an empty SD card .
Any help would be appreciated
Thank You
7 REPLIES 7
deebatman316
What lens are you using Canon or 3rd Party.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Hello thank you for your reply but i do not think it has any relevence to my problem , but thank you any way.
I have seen bad lenses do this to cameras. Such as draining the battery preventing the camera from turning on.
-Demetrius
Thanks for your reply iam using a brand new 100-400mm USM II lens
What happens if you use a different lens does the camera still give you problems.
-Demetrius
Thanks for the thought i will try it next week with a different lens and will get back to you ,
Never thought about it being the lens , but i will give it a try.
Many Thanks for your imput.
Just because something is new doesn’t mean that it’s functioning correctly. Did your problems start when you got this new lens. Was the lens purchased new or was it purchased used but new to you.
-Demetrius
Friends and Family
