EOS 850D, SD card not showing on windows 11
wezza2
Hi everyone, I have just bought an EOS 850d.
Playing about with it today to try and get used to settings etc, took a few photos and wanted to view them on my PC. I used a micro sd card plugged into an sd card adaptor, card is correct spec etc. Photos show on camera as on card but when I plug the card in to my PC it doesn't show the drive being plugged in. I thought it might be an issue with card reader but it recognised the sd card I put in from my drone.
Any ideas why this sd card that was formatted in my camera wouldn't be showing up on windows at all?
8 REPLIES 8
Anonymous
Not applicable
You should be using a full-size SD card and not a micro SD card with an adaptor. They are known to cause problems in the camera. If you have picture files on the card, I would try another card reader and cable. I highly recommend getting a full-size SD card and not using the micro SD card for your camera.
Anonymous
Not applicable
You could connect the camera to your computer with a USB data cable to try to transfer the files in the camera memory card to your computer. After getting them off the card, don't use the micro card for the camera.
stevet1
wezza2,
You can use an IFC-600PCU cable and Canon's EOS Utility software for the transfer.
The cable is sold seperately ,and you can buy it direct from Canon. The software is free from Canon.
I use it all the time with my 850D.
See p.707 in your Manual.
Steve Thomas
Anonymous
Not applicable
You don't need the EOS Utility to transfer photos, Windows File Manager will see the camera's memory card.
Tintype_18
I transfer photos with a standard SD card to Explorer. It takes a couple of extra steps as opposed to W10. I load directly by inserting the card into a slot on my laptop. I used a card reader but eliminating that one extra thing would be better.
John
Waddizzle
“ I used a micro sd card plugged into an sd card adaptor, card is correct spec.
No, a micro-SD card with an adaptor is not supported in any Canon DSLRs.  The User Guide is quite specific in stating SD, SDHC, and SDXC.  The micro-SD card types are not listed and are completely different card type.
Only use full size cards that you have bought from a factory authorized Canon dealer.  These vendors are 100% reputable, unlike most of the vendors that you may encounter in online marketplaces like Amazon and eBay.  Always be sure to format memory cards in the camera prior to first use.
Also, the memory card in the camera is not a recommended place to store photos.  Download them to a computer at the earliest opportunity.
BookiiRivas
There are many reasons why the SD card is not showing up on Windows. However, at least you can be sure that the issue is not with the computer or the card reader.
Open Disk Management in Windows (Right-click on "This PC" > "Manage" > "Disk Management") and see if the SD card shows up there. It might be present but without a drive letter assigned.
Make sure the SD card is genuine. SD cards sold at unusually low prices are often counterfeit. For more basic solutions, this blog might be helpful.
Tronhard
VIP
VIP
Hi and welcome to the forum:
As my colleagues have alluded to, using a micro SD card with an adapter is not going to work well with a camera, and not just Canon ones.   The adapter creates an extra 'dry joint' interface that can cause all sorts of reliability issues.
Definitely get full-size SD cards from respected brands, such as Lexar, SanDisk, Prograde and from real stores or authenticated on line sellers - there are lots of counterfeits out there, so if it seems like an amazing deal from some on-line seller (even some on Amazon), then regard it with suspicion.   You don't need to go above 64GB, and you would be better with a couple of small capacity cards than one large one.
cheers, TREVOR
