EOS 6D Strange Nearby Object Appearing on My Photos as Ghosts
RaphaelC
my canon 6d is showing ghost images of objects nearby on the actual photograph am taking, am confused i don't know what to do, check the images here
The Logos from the material are suddenly visible on her, note that the results are the same in live view too, please help, i have a canon 50mm lens
5 REPLIES 5
deebatman316
Which EF 50mm lens are you using. Canon has released multiple EF 50mm lenses over the years. You could also be seeing dust on the the image sensor. Can you see the ghosting in the viewfinder too.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
rs-eos
Were you behind any type of glass (shooting through it)?
What's interesting is that the emblems are upside down as it appears on her.
Ricky
It is.
Do you have another lens you can test with?
Are you shooting any video.
Trying to determine what would cause these artifacts.
jaewoosong
Rising Star
Rising Star
Do you have a filter on your lens?  If so, remove the filter.  It may be reflecting the ghost image.  Since the table where the pattern is and the subject is in similar focal plane and both in focus, it's highly likely due to filter.  Might be fixed by cleaning the filter if there is any greasy film on the surface.
-jaewoo
Rebel XT, 7D, 5Dm3, 5DmIV (current), EOS R, EOS R5 (current), R50V (current)
@RaphaelC,
Any updates for us?
