12-02-2020
03:51 PM
10:03 AM
I updated the 6D to the latest firmware 1.1.9 today.
The reason for updating is that I saw the above message on the camera menu when I pressed on firmwaure version under the copyright information.
I carefully followed the steps according to the downloaded instructions. Firmware update has been successful. I switched off the camera and removed the battery. Then I inserted the battery to start up the camera. The firmware was updated to 1.1.9.
I formatted the SD card in the camera. Then I restarted the camera.
When I pressed on the set button and re-checked the firmware, the above wording appeared. I then inserted another SD card and formatted it in the 6D. Checked firmware version and "Memory card containing firmware is required to update" popped up.
Is that an error ? How do I do to remove it. I have low level formatted the cards. The second card definitely never has any firmware on it.
Please help.
12-06-2020 10:11 AM
@lly3988 wrote:
I believe that it is a software design that existed for many years. The prompt is a reminder telling the camera users to insert a memory card with firmware file for update. I just turned on my 40D, 7D, 5D mark II, 6D and M50. They all behaved like the OP has mentioned in the earlier posts. They all have the prompt. Some wordings are slightly different. " fairly isolated and unique nature of...." Really ? I doubt it. I will go to Costco and Walmart and investigate further with their newer cameras. Let's be scientific and not just be defensive. Please let the Canon experts tell the fact.
I am able to reproduce the message, too, in every camera body.
It would seem that this has been a case of operator error all along.
12-06-2020 12:52 PM
12-06-2020 01:52 PM
@lly3988 wrote:
What kind of operator error ? That's is a groundless allegation.
I found a Rumour site has a reply to the same phenominium.
BTW, do you really have a Canon camera ? hahaha
The message is normal.
Users should only select that menu option when they wish to upgrade the firmware. Seeing the message and thinking something is wrong with the camera is an operator error.
12-06-2020 03:13 PM
12-06-2020 03:49 PM
@lly3988 wrote:
But you were saying in your former reply that :
It sounds like either the update did not complete, or the firmware file was not erased.
And now you said that it is normal. Really ?
Users should scroll and learn every menu option. And to read the Camera Instruction Manual. That's the first step to fully explore the camera. And then of course, start shooting.
I have heard some people saying do not touch the camera. You are going to break it. I do not agree.
Explore every feature of your camera even though you may not need them in your daily photography.
It is a normal message.
If the user pressed the button to start an update, but never inserts a memory card into the camera, guess what that mean? The update did not complete. Someone was pressing the button start a new update, not realizing they were asking the camera to update itself again.
Have a nice day.
08-18-2023 12:37 AM
Sir madam please help me
memory card containing firmware is required to update
Camera model -EOS 800D
New version update file link share please help me 🙏
08-18-2023 01:40 PM - edited 08-18-2023 01:46 PM
Could you start a new topic with the information included of what you are doing when you see this message?
