EOS 6D Mark II Doesn't Want to Turn On
shasta
My 6D has not been wanting to turn on. I replace the battery and card several times and it will finally turn on after a few times. Has anyone else had this issue?
14 REPLIES 14
Will the camera act up with your old SD cards. As Tronhard mentioned avoid using micro SD cards in an adapter they cause they too many issues.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Tronhard
VIP
VIP
I think it is time to consider calling Canon Tech Support at 1-800-OK-CANON.  They can help you further and if necessary set up the process to have the camera serviced.
cheers, TREVOR
In addition to the great advice above, and after removing card, lens, etc.  Please perform a factory reset on the camera.  Do both the camera and custom (C) menus reset.  Then retest.
We also need to ask if the camera's power switch is loose or faulty?..  and have you upgraded the camera's firmware by chance?
kotty1
I have an exact issue with my 6d mark ii
“ I have an exact issue with my 6d mark ii “
I have had this experience when the battery grip had somehow loosened up.  I tightened it back up and the camera powered up.
