06-28-2023
01:46 PM
01:53 PM
Hi, I am a photographer in Dubai,
I have been given an opportunity to shoot in some of the very famous clubs with some of the coolest DJ's,
I want to know what the best settings are for night clubs and low light/hyper active light when taking photos & video.
I have played around in similar settings but never in a professional manor.
Please can someone help with as much detail as possible?
06-28-2023 01:47 PM
Thanks for joining the conversation, crossphotos! So that the Community can help you better, we need to know exactly which Canon camera model and lens you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
06-28-2023 01:52 PM
So sorry! I am using a Canon 60D, and lens tends to be Sigma 17mm-70mm, Macro HSM by default.
06-28-2023 02:17 PM
Low light will be challenging. Even with your f/2.8 lens. For photos, I would recommend starting at around 1/125 second and then ajusting ISO as needed. If you find that you end up with very high ISO (and thus lots of noise), you're only options would be:
For video, would recommend capturing in either 24/25 fps (using a shutter of 1/50 sec) or 30 fps (shutter of 1/60 sec). Adjust ISO as needed. If you find your footage is still too noisy, the same recommendations for photos would also apply.
06-28-2023 05:14 PM
Actually this is a variable aperture lens F/2.8-4.0 which could cause some problems with low light. But its not as slow as an F/3.5-5.6 variable aperture lens.
